Hello everyone,
I just tried to work on Maya 2018 and the viewport doesn't show up, i uninstalled et reinstalled the program.
Then i tried to activated the grid or show the viewport but nothing happends, I just have a grey screen.
Does anyone had this problem before?
my config:
OS: Windows 10
CPU: Intel Core i7-6700HQ
Graphics Chipset: NVIDIA GeForce GTX 970M
RAM: 16GB
Solved by mspeer. Go to Solution.
is the complete window grey? Or do you see any UI elements?
What about the „Workspaces“ menu in the upper right corner of the window?
Try switch to another workspace.
I can see the UI elements and i can change the workspace but the viewport it's still grey.
Actually, If i open a file or create a primitive, nothing shows on the viewport.
I really don't understand
By the way, i can see and use the hotbox when i hold the space bar but nothing i select do anything in the viewport.
Hi!
1. Make sure to use latest GPU drivers (or try older ones).
2. Deactivate any other (onboard) GPU.
3. Try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
