Announcements
UVs not showing up in Maya after exporting an obj from ZBrush
I have this simple mesh that I exported from ZBrush as an OBJ, I want to create the UVs in Maya but they don't show up, I tried lowering the texture resolution in the viewport 2.0 but it didn't work. Here is the file, it would be great if someone can help. Thanks in advance! Btw, I'm using Maya 2020.
https://mega.nz/file/E8ACkTzL#YXOjvMqFIEOwAR0Dxb3-bGSaQN32HWBKD-fw1Sl8WtQ
mspeer
Hi!
The OBJ file does not contain any UVs.
In Maya you need to create new UVs first before you can edit them.
Select the object and in UV Editor try:
Create -> Automatic
Thank you very much @mspeer ! That solved the problem 🙂
