Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
UV Texture Editor thick lines...
damaggio
Mentor Mentor
damaggio
After starting with a new preferences Maya 2015 is again displaying the UV lines with a very thick line...display texture border is not enable and all shells now have a thick annoying line....is there a hidden new setting that has been introduced in 2015?...
Has anyone come across this problem and know how to fix so I don't need to rebuild all my preferences from scratch again.
santd
Thank you for posting to The Area Forums.
I haven't seen an issue with this and I don't believe a new option has been introduced that does this in Maya. I understand that the texture border option is not enabled. However, try toggling on off to see if for some reason it is stuck. It seems to me that you are using preferences from a previous version which can cause funky issues and corrupt some of the Maya settings as programmaticly there are differences in a newer version, that may not play well with the preferences of a previous version.
If you default your preferences, you don't necessarily have to start from scratch. You can always move your custom scripts, shelves, icons, etc. one folder at a time to see which one causes the issue and then only have to reset that particular setting or file.
I hope that information is helpful.
Cheers,
David Santos
damaggio
There was another post by the user below...I started again with another fresh preferences and just moved over a few folders and the issue is not happening right now.
Thanks for the reply Santos.
http://forums.autodesk.com/t5/shading-lighting-and-rendering/uv-texture-editor-thick-lines/m-p/52398...
