Announcements
UV editor super slow!
klawchi
Message 1 of 8
klawchi
I have 50 UDIMs in my scene and it takes ages to select and move one UDIM, it's very slow!
Sometimes when I try to select and move one of them I get this error:
// Error: file: C:/Program Files/Autodesk/Maya2019/scripts/others/texturePanelMenus.mel line 2298: Object's name 'MpolyTexturePlacementPanel1UVSetTooManyObjects' is not unique. //
I don't have History and there is no transformation on the objects and I don't have symmetry on and I don't have anti-aliasing on.
Why is it so slow?
Replies (7)
Message 2 of 8
klawchi
I've been waiting for 5 min after I clicked on "Set" from Texel Density! Seriously?
Autodesk please fix the UV Editor, it has serious issues.
Message 3 of 8
knadtochiy
Community Visitor
Community Visitor
The UV mapping is painfully slow for me as well, also I see that Maya uses only about 25% of the CPU processing capacity. Any reason why this might be happening?
Message 4 of 8
amaterasu-qbb
try to delete maya's prefs file from your document folder.
if already done sorry.
Message 5 of 8
johnnyzxt
Me too, Maya 2019.3, the UV editor is sooooo slow~~~, I found it will read the textures, which textures are on the network disk, so I disable "display map" in the UV editor, it has no help. But you can put your texture on the local drive, that will be better. But it still a bad UV editor experience.
Message 6 of 8
estesanta
Community Visitor
Community Visitor
I did: Freeze transform and delete history and it's fluid again
Message 7 of 8
gaboreturi
Exact same issue, the difference is that I write this in 2023 and issue not fixed! Nor any solution 😞 Hold back the job very much
Message 8 of 8
amaterasu-qbb
Hello everyone. Do these issues resolved in Maya 2024?
