Hi forum,
I think there's something wrong with my value sliders because they increase the max height to a way too high value depending on the interaction.
instance 1: when I type 5 as the value, the max value goes from 1 to 10000. Resulting in not being able to drag the value manually. This same problem exists in the sculpting intensity, except it's set to very high from the start.
instance 2: The value is set to 6 here ( manually typed), when I drag the value up, it increases to 6000.
I hope someone knows a solution, it's taking me a lot of time to adjust the settings by typing out each time 🙂
Thanks in advance
