Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Unsmoothed wireframe on smoothed mesh?
5 REPLIES 5
11433 Views, 5 Replies
Hi, I don't know why, but me meshes keep on showing me unsmoothed wireframes in the viewport of maya 2018. Can somebody help!?
Here's a picture to show you the problem.
Just to make everything clear, Theres only one mesh with this problem in my scene, the others are perfectly normal!
Tags (1)
5 REPLIES 5
mspeer
Hi!
You have either enabled
- Cache + Smooth Mesh (hotkey 2), or
- Displacement Preview
Check in Attribute Editor ...Shape -> Smooth Mesh
Please read the Maya Online Help / Documentation for more details.
I found the answer. For a reason I don't know, in the Shape of my mesh, the smooth mesh preview was set on  Cage+ smooth mesh! Thank you for your time!
230187G
in reply to: mspeer
Hi, I'm using Maya 2024 and I have this same exact issue when I use hotkey 3. It smoothens my mesh but not the wireframe, and when I press hotkey 2 it displays the same thing. I found the attribute editor and under smooth mesh when smooth mesh is enabled (Not cage + smooth mesh) it still shows the same as the cage + smooth mesh.
Do you happen to know the solution for this on Maya 2024?
Edit: the photo here is what is displayed when I press hotkey 3
byc6484
in reply to: 230187G
im having the same problem 😞
byc6484
Just accidentally found the solution, de-select "Displacement Preview" and instead select "Subdivision Method" box
