Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Unable to scale with MASH audio node.
0 REPLIES 0
Message 1 of 1
mirza8hamza
285 Views, 0 Replies
Hi guys
I am struggling with MASH Audio Node. I'm trying to make a 3D spherical music visualizer. For that I created a sphere then separated the faces and extruded them a little (to turn them into cube shapes). then added them into the mash network and applied the audio node, but it was effecting the position instead of scale. to try and fix that I tried to go back and set the pivot point of each and every object but that didn't work either.
I've attached a screen recording with this post to help you understand the problem better.
I've been stuck at this for so long, couldn't find the solution elsewhere.
I'd appreciate a working solution very much.
Labels (3)
0 REPLIES 0
