Hi
Is it possible to turn off edged faces like you can in 3ds Max? In Max, you can toggle them on/off with F4. Is it possible to do this in Maya? Thanks.
Solved by Abdulla-Qaladzay. Go to Solution.
Those settings are already disabled for me. The edges show if I have an object selected, but I want to know if they can be turned off when an object is selected.
sorry that wasn't clear for me at the beginning .
now I guess it is exactly like 3ds max:
-go to Preferences => Display => in view section change wireFrame on shaded to non.
and it is a little script to toggle it (we know that we can easily assign a custom keyboard-shortcut to it):
string $active =`displayPref -q -wsa`;
if ($active == "full"){
displayPref -wsa "none";
}else {displayPref -wsa "full";}
and there is some thing else witch quite the same thing which it is selection highlight:
watch the video attachment "wiresViewPref.mp4"
Sorry, guess I wasn't clear myself. All those settings are enabled. But that custom script works like a charm. Thank you. 🙂
