Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Trouble opening .ma scene in Maya 2022
4 REPLIES 4
t18arva
865 Views, 4 Replies
I try to open an .ma scene but I get this error message with the title "Unsupported nodes":
"Errors have occurred while reading this scene that may result in data loss. Please check the Script Editor for details".
Then Maya freezes, I can't click "OK" to close the error message (or click on anything else in Maya) and I have to close Maya using the Task Manager.
The .ma file is downloaded and I use Maya 2022 version.
Please help, thank you.
Tags (2)
4 REPLIES 4
mspeer
in reply to: t18arva
Hi!
Here it works.
What exact Maya version and OS are you using?
Try File -> Import instead of File -> Open Scene.
If it still does not work I will convert the file.
t18arva
in reply to: mspeer
I  tried that and all alternative ways that a file can open in Maya but nothing worked. How can I convert the file?
Thank you for your help.
mspeer
Hi!
Please try to open the attached scene.
t18arva
in reply to: mspeer
Yes, this works! Thank you so so much!!!
Can I ask how you solved the issue in case this happens again?
