Time slider preferences error
lasercade
5.488 Vistas
12 Respuestas
Mensaje 1 de 13
lasercade
I'm using Windows 10 Maya 2018.1
I'm trying to save my Frame Rate preferences to 25. Whenever I change from the default of 24, I get this error message:
// Error: file: C:/Program Files/Autodesk/Maya2018/scripts/startup/createPrefWndUI.mel line 2580: Object 'animEdCadenceLineType' not found. //
I can see that in my Userprefs, the save is being made, but whenever I restart Maya, it defaults back to 24.
Any clues as to how to fix this?
mm
0 Me gusta
Soluciones aceptadas (3)
5.489 Vistas
12 Respuestas
Respuestas (12)
Mensaje 2 de 13
mspeer
Hi!
1. Try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
2. Set frame rate in File -> New Scene [options].
0 Me gusta
Mensaje 3 de 13
lasercade
This didn't work for me.
I've totally uninstalled all of maya 2018, and reinstalled (including the .1 update). I am using completely new preferences.
Whenever I change the preferences: Settings > Time Slider > Framerate: to 25 fps, I get this error:
As you can see, it is not an error with the preferences, but seems to be something to do with the scripts folder in the program files directory.
If I look at my userPrefs, I can indeed see that the settings have been saved to 25fps, but Maya always defaults to 24 on restart.
Thank you for your help.
0 Me gusta
Mensaje 4 de 13
mspeer
Solución aceptada
Hi!
1. Re-installing Maya does not reset preferences, so as suggested in my previous message, please try a reset of everything ... maya folder to maya_backup. Test it.
2. Again: FPS for a new scene is set and saved in File -> New Scene [options] + saving of Preferences.
Mensaje 5 de 13
lasercade
Hi, I totally trashed the previous 2018 preferences when I did my reinstall, so that maya needed to create a brand new prefs folder. It changed nothing. Just now I renamed the maya folder as maya_backup as you have suggested (again, so that maya would create a new one). Same error. It doesn't seem to be an error with the preferences.
0 Me gusta
Mensaje 6 de 13
sean.heasley
Hi @lasercade
I just tried changing the time slider to 25fps on a fresh install of 2018 and had no issues.
When you uninstalled Maya, did you perform a clean uninstall/reinstall of Maya? This will completely remove all Autodesk/Maya folders so you can start with a fresh slate.
Let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
0 Me gusta
Mensaje 7 de 13
sean.heasley
Hi @lasercade
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
0 Me gusta
Mensaje 8 de 13
lasercade
Hi all,
Thanks for your help.
I have now done a full clean install of 2018.1, per the notes on Autodesk's website. With a completely fresh install (new maya folder any everything removed from the TMP folder, etc.) I still get this error when changing the preferences for Settings: Time or Time Slider: Framerate.
The only oddity is that on re-installing 2018.1 update, the installer choices only gave me the choice to 'install' (only Repair, uninstall or close). I chose Repair, and the installation took a long time (15 minutes?) but installed without errors.
The only other Autodesk product I left installed is 3dsMax2013.
thanks,
mm
0 Me gusta
Mensaje 9 de 13
sean.heasley
Hi @lasercade
Did you try @mspeer's steps about creating a new scene with the option box so you can set it to 25 fps?
0 Me gusta
Mensaje 10 de 13
lasercade
Solución aceptada
Hi Sean and Mspeer,
Thanks for sticking with this. After reinstalling everything and doing what mspeer suggested (New Project> Settings, save settings) and restarting, it looks like I can now open Maya with a default of 25fps! This didn't work in my previous attempts. It's the little things...
Thanks!
mm
Mensaje 11 de 13
No aplicable
 HI! I HAVE THE SAME PROBLEM BUT I CAN´T RESOLVED,
I CLEAN UNINSTALLED MAYA MANY TIMES , AND I INSTALLED OLD VERSION BUT THE TIME LINE RUN VERY QUICKLY, ALSO I CHANGED THE PREFERENCE, SAVE AND RESET MAYA, AND RESET PREFERENCE TOO.
COULD YOU HELP ME PLEASE?
0 Me gusta
Mensaje 12 de 13
sean.heasley
Hi @Anonymous
Are you seeing the error as well?
Can you post screenshots of what's going on in your scene?
0 Me gusta
Mensaje 13 de 13
No aplicable
Solución aceptada
I JUST RESOLVED, I CHANGED THE OPTIONS IN PLAY BACK SPEED AND FRAMERATE IN 25 IN SETTINGS, THEN  I SAVED SETTIGNS AND RESET MAYA, BUT THE MENSSAGE STILL APPEAR, BUT IT WORKS. THANK YOU
