I'm making some clips in the Time Editor, modifying imported clips and making clips to referenced characters, etc. When I re-open the session the Time Editor stopped responding to any command, when I try putting a clip to it, it's not accepted, when I try adding a track it's also not accepted, instead Maya presents Errors. When I delete 'timeEditor' node in the Outliner it gets deleted, something that is usually forbiden by Maya, so I assume the Time Editor stopped working and don't get to work when I reinitiate Maya.
Is that a known issue? Why is it happening? Have I lost the clips I already made??
I can't even export them, because it requires the Time Editor to be working...
Some of the Errors I'm getting:
- Adding a track to Time Editor: 'Error: No track specified'
- Dragging a clip to it: 'Error: line 1: Track should be in format <trackNode>:<trackIndex> or full path "composition1|track2 '
- Clicking the button to add an animation from the scene: ' Warning: file: C:/Program Files/Autodesk/Maya2023/scripts/others/teCreateContainer.mel line 1396: No composition found in the scene.'
