The xgen utilities tab is empty
geeguit
geeguit
In maya 2019 the xgen utilities tab is empty! I tried to reset the pref folder. Reboot, but nothing helped. What is the problem?
Replies (17)
sean.heasley
Hi @geeguit
Try unloading and reloading your Xgen plug-ins found in the plug in manager.
geeguit
Thx, but still dont work..
sean.heasley
Hi @geeguit
I looked into this more and it is actually a known critical issue and the developers are already working on fixing it asap.
when this problem will fix ? i need use xgen ;|
Christoph_Schaedl
There is a was to fix it. Thanks to Luke Harris!
open the xgUtilitiesTab.py
C:\Program Files\Autodesk\Maya2019\plug-ins\xgen\scripts\xgenm\ui\tabs\xgUtilitiesTab.py, line 115-118
and rename    $gxgmTMLookupTable     to --->    $gXgmTMLookupTable
https://linktr.ee/cg_oglu
mspeer
Hi!
In previous Maya versions the lower case has been correct, so care as this may change again with an update.
onliiaj
Hi!
I did that, it didn't work for me, utilites still empty (and I'm using Maya 2019). Is there any other solution?
hi i am using maya 2019 it works if you make sure you renamed the 'x' to 'X'  in both xgUtilitiesTab.py and  xgUtilitiesTab.pyo files for every instance of  $gxgmTMLookupTable    (file path C:\Program Files\Autodesk\Maya2019\plug-ins\xgen\scripts\xgenm\ui\tabs  )
geeguit
Make sure that changes to the file are saved. In my case, due to a conflict with disk administration, the system did not allow me to make changes to the file. I copied it to another disk, made changes to the lines, and copied it with the replacement back. And it all worked!
onliiaj
Yes, I've had the same issue, couldn't save it. But I saved my file and reopened it in Maya 2018 (where xgen was totally lost, that's why I tried 2019 version), and that file kinda made it appear again, so it's all fine. Thank you for your help 🙂
I have located the file but don't know how to change this script if that what it is, any help would be much appreciated.
Thank You,
carlosZ2A2Q
Community Visitor
Community Visitor
open the text file, you can ctrl(or cmmmand) F to search for the line then replace the lower case x for X and ctrl or cmd save the file.
I updates the python script which fixed the ui. After grooming, it no longer displays the guide curves.
"The Grooming tools are only avilable for groomable splines"
Any way around this?
First off THANK YOU SOOOO VERY MUCH!!!! I tried all these other solutions with no success. This WORKED! i desperately needed this tool and appreciate you explaining it that I could follow!
eileneje1
Observer
Observer
I had difficulty finding the files to change, but finally found them in a strange path because I have Maya 2019 and 3ds Max 2020.  Here's where I found mine - in case it helps someone:
Program Files\Autodesk\3ds Max 2020\Maya2019\plug-ins\xgen\scripts\xgenm\ui\tabs
mayer.elena90
Community Visitor
Community Visitor
This problem is not resolved yet. I'm using Maya 2023 and when I launch Maya seems working propertly but after I change the tab is empty again (forever), please fix it.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
