The UV set editor won't open
Recently, the UV set editor can't open, I don't know what is wrong with Maya, which is very strange, but I don't want to delete the Maya documentation to solve this problem, that would reset Maya's personal habits.
I hope some expert can come up with a better solution. Thank you very much.
patrick.schock
Autodesk Support
Autodesk Support
Hello @Anonymous,
resetting the Maya user preferences will most likely solve this issue. You can find instructions how it works here: How to reset the Maya Preferences to Default.
Please make sure that Maya is closed in advance of renaming the prefs folder. In case that you want to store your personal settings like hotkeys, shelves, you can copy-paste the folders hotkeys, shelves and the file userNamedCommands.mel into the new prefs folder that is being created at the new start of Maya.
If renaming the prefs folder did not solve the issues, you can also try to rename the version folder and copy-paste the relevant files that you want to keep. For example: C:\Users\YourUserName\Documents\maya\2020.
It happens from time to time that a reset of the user prefs makes sense. From my own experience, I was often missing the UV editor when it was opened on my 3rd screen and the next time I opened Maya on another screen, I could not open the UV editor. Resetting the user prefs did the trick to get it back quite quick.
Hope this helps!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
steveMPAPA
Community Visitor
Community Visitor
For me it was something to do with the Display driver. I opened the maya file. Then go into display settings by right clicking the desktop. Switch your screens around 1 to 2 position then apply. Have a look for your UV window. Move your UV window over to the screen you want to use it on. Switch your screens back in Display settings and apply. Make sure the UV window is still visible and working the way it should. Then save the maya file and close Maya. This will save your preferences correctly. Reopen Maya and the the problem is fixed.
