texture problem error
foxsuno
foxsuno
 Hi!
 I did a eye, with 32bits maps, rendered it in vray, everything was fine, so i get my things and ported to the main scene and "TIFF image class not supported (must be 8 or 16 bits)" i searched and discovered that maya does not support, okay. But why in my scene test it does work, i tryed to redo my config in other scenes and does not work, but in my test scene work fine, i can't get what it's happening.
 ps:Only my mask, that i use to separete the sclera from cornea does not get reconized, the other files work fine.
Thanks for the help.
>my render working in the test scene
foxsuno
So i did a lot of test here and i maybe i found a bug, my file texture, somehow accept my mask, but is this ONE file texture, if it's a new one, the error appears, if i duplicate the one that is working, my transparency works fine.
 I did my shader setup a lot of times, duplicate the "working ones" and it's the only thing that get this error is this file texture, so checked everything in the node, to make sure if nothing is wrong and in the duplicated one in Color space appears "Color management - OFF" and the duplicated one works fine in the render and the original one appears that the Color space is set to sRGB and working fine (????), so i truly belive that i found a bug, if someone could help me how to procced.
Thanks.
foxsuno
 Help please?????
 Thanks.
mspeer
Hi!
The following commands create a copy of a file-node without connection to the Color Management.
Main Menu
A) Edit-> Duplicate
B) Edit-> Duplicate Special (default settings, duplicate Input Graph/connections "off")
C) Edit-> Duplicate with Transform
Hypershade Menu:
A) Edit-> Duplicate -> Without Network
Workaround:
Use any other option for creating copies of these node type.
Please report this problem (bug?) to Autodesk.
Help -> Speak Back -> Report a Problem
