Announcements
Texture not moving with UV shell accordingly
I already had this issue and I fixed it but I do not remember it at present time.
I have a model.
I applied on it a material made with the base color : UVGrid07.jpg.
When I move the UV shells in the UV Editor, the texture is not moving on the model.
What's the issue.
Thanks for your help.
I didn't touch anything and it runs again.
mspeer
Hi!
Check for multiple UV Sets.
sean.heasley
Hi @Anonymous
I'm just checking in to see if you need more help with this. Did the suggestion that @mspeer provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
