In Maya 2020 this is broken. When I select a channel in the outliner, it does not isolate it in the graph editor. Anyone else getting this?
Cheers
Cheers
Hello @gimble,
this should be fixed already. Can you please reset your user preferences and see if it helps?
If not, can you please send me a short screencast to reproduce your steps in order to log it again?
Thanks and best regards,
Patrick
Hello @gimble,
Patrick
Hi Patrick,
Thanks for getting back to my post on this problem and no it's not fixed because it still happens to me on a daily basis. And also I always reset my prefs every single morning before opening Maya, so it's not that. I'll make a video of it tomorrow when it happens again. I'm sure lots of animators are experiencing this in Maya 2020 right? It's quite easy to reproduce.
Cheers,
Craig
Hi Patrick,
Cheers,
Craig
try to uncheck both the sync options and then turn them on again and see if that fixes it
