super annoying bug that requires force quit
nick.holliday
Message 1 of 11
nick.holliday
Everytime i hover over the menu to assign  new materials i get this error ehich im unable to escape for and so need to force quit.!  I cant be the only one (i know im not).  Surely this could/should be fixed asap?
Replies (10)
Message 2 of 11
Christoph_Schaedl
Which Maya and Arnold version are you using?
https://linktr.ee/cg_oglu
Message 3 of 11
nick.holliday
Hi
im using 2024.1  and arnold 5.3.1.1
Message 4 of 11
brentmc
Which platform are you running Maya on and do you have any other plugin shaders loaded?
Also, could we get a bit more detail on how to reproduce the issue. Like a screenshot showing which menu are you are hovering over when the error occurs.
Thanks.
Brent McPherson
Principle Engineer
Message 5 of 11
nick.holliday
sorry, it was a bit of a rage post. Ill get a video  (im on windows 11)
Message 6 of 11
nick.holliday
Her'es a vid. It doesnt happen with every mesh.  Just certain ones.
Message 7 of 11
brentmc
Hi Nick,
Thanks for this. Any chance of getting one of the scene files that triggers this error?
You can send it to brent.mcpherson@autodesk.com and it will only be used for investigating this issue.
Thanks.
Brent McPherson
Principle Engineer
Message 8 of 11
brentmc
Hi Nick,
A quick update on our investigation.
The security issue is coming from the uiConfigurationScriptNode in the file and deleting these two lines from the file fixes the issue.
-docTag \"isolOutln_fromSeln\"
-docTag \"RADRENDER\"
There are also settings in Preferences > UI Elements that prevent Maya from generation and/or using the uiConfiguration node and disabling these also avoids the issue in my tests.
Thanks.
Brent McPherson
Principle Engineer
Message 9 of 11
nick.holliday
oh!  thanks for the update - ill give it  try.  Was there something i did that might have caused that to happen?
Message 10 of 11
brentmc
No, it isn't anything you have done.
It only seems to happen in the context menu, not in the main Lighting/Shading menu in the main menubar!?
Another workaround is to uncheck the Python compile command in the Python Security preferences:
Brent McPherson
Principle Engineer
Message 11 of 11
nick.holliday
thanks again. It seems unchecking those initial prefs seems to have done the trick!
