Announcements
Stack Trace error in Viewport 2
I am using Maya 2019 and while working in scenes with viewport 2.0 and move around the scene i get the below error
I have a Nvidia 1080 Ti Graphics card with the latest drivers. With Windows 10
What could be the cause?
Stack trace:
  OGSDevices-16.dll!OGS::Devices::DeviceContextCache::DeviceContextCache
  OGSDevices-16.dll!OGS::Devices::VertexBufferBuilder::AddVertexBuffer
  OGSRender.dll!OGSMayaConsolidatedNode::sAddToConsolidationMesh
  OGSRender.dll!OGSMayaConsolidatedNode::sAddToConsolidationMeshWithVertexFiltering
  OGSRender.dll!OGSMayaConsolidatedNode::Consolidate
  OGSRender.dll!OGSMayaLODConsolidationNode::ClearAllMemberInfo
  tbb.dll!tbb::interface7::internal::task_arena_base::internal_wait
  OGSRender.dll!OGSMayaLODConsolidationNode::RealizeNode
  OGSGraphics-16.dll!OGS::Graphics::SwapAgent::RealizeNode
  OGSGraphics-16.dll!OGS::Graphics::SwapAgent::Visit
  OGSGraphics-16.dll!OGS::Graphics::TraversalState::Reset
  OGSGraphics-16.dll!OGS::Graphics::APipeline::Run
  OGSRender.dll!OGSMayaBufferManager::operator=
  OGSGraphics-16.dll!OGS::Graphics::ScriptInterpreter::RenderFragment
  OGSRender.dll!OGSRenderGraphCompositeComponent::popPassSemantics
  OGSRender.dll!OGSRenderGraphManager::evaluateGraph
  OGSRender.dll!OGSRenderGraphManager::renderGraph
  OGSMayaBridge.dll!Ttask::sIsMTSchedulerEnabled
  OGSMayaBridge.dll!OGSApplicationBridge::UpdateScene
  OGSMayaBridge.dll!OGSMayaRenderer::updateScene
  OGSMayaBridge.dll!OGSMayaBaseRenderer::performSceneRender
  OGSMayaBridge.dll!OGSGeometryEvaluationOverride::~OGSGeometryEvaluationOverride
  DataModel.dll!TidleRefreshCmd::refreshOGSRender
  DataModel.dll!TtoolRefresh::refreshFast
  SharedUI.dll!TtrackContext::dragAction
  SharedUI.dll!TstandardContext::preDoDrag
  Manips.dll!TtransformContext::preDoDrag
sean.heasley
Hi @Anonymous
First you'll want to check to make sure your GPU driver version matches our certified hardware list for Maya 2019.
You can find our certified hardware list here!
Second you could try going to Windows->Settings/Prefs->Prefereces->Display and change the Rendering Engine settings.
Are these warning causing any issues with your Maya or are they just appearing as you work?
Maya totally crashes when i get this error.
sean.heasley
Hi @Anonymous
In that case it may be the dll files causing the issue so you'll want to perform a clean uninstall/reinstall of Maya.
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
