When I import the music into the Maya scene it only plays when I scrub the timeline and I have the playback setting to real time which seems to resolve the issue for many but not for me..
Solved by BenBisares. Go to Solution.
I assume that your Evaluation Mode is set to DG? Assuming yes, then right-click on the timeline and disable "Cached Playback".
Sound should play after that. Let me know if that works.
A couple of things I can think of:
