Soft Body
Soft Body
Message 1 of 11
Soft Body
hey, I'm pretty much a rookie with Maya and I was trying to achieve a soft body but I couldn't make get it.
When I apply a soft body to a sphere I can modify its attributes to get something like a deflate or even that it bounces but I'm not sure why it's not a real soft body, like a jelly or flexible ball. I'm definitely missing a parameter here but I'm not sure which one gets the trick because all I get it's not really soft
Replies (10)
Message 2 of 11
mspeer
Hi!
A lot of Info missing, like current network and settings (maybe upload a scene-file).
If Soft Body doesn't fit your needs, you could try nCloth instead, there are also some presets available.
Message 3 of 11
john.paul.giancarlo
I am guessing you are using the bullet solver !
could you please share your file or show us your settings, maybe an example of what you are trying to achieve!
Cheers
Message 4 of 11
yep, I'm trying to use the bullet soft body I was hoping to get something along this line even if this is done with Real flow. Trying to get a "jelly-like" body, something that bounces like that, but I'm missing the parameters that make that soft, all I can get it's something that bounces maintaining its shape or that deflates like with the ncloth.
https://www.youtube.com/watch?v=3nE2dzpzxtc&index=123&list=PLzInrU1w5Lhc4tEoc09VKyWuMI_v5YkKC
Message 5 of 11
john.paul.giancarlo
for this I would use ncloth ! use the first preset and go from there! it is much faster to set up and play with!
give it a try and let know how you get on! maybbe I can post a sample scene if you can’t make it work as you llike
but I am sure you will do it with ncloth a lot faster!
Message 6 of 11
john.paul.giancarlo
Hello friend I have made a test scene for you to have a look! find it attached
Message 7 of 11
That's lovely. It's clearly way better to go this way than going on with the bullet, thanks for the heads up, and for the scene, I really appreciate it.
Message 8 of 11
john.paul.giancarlo
you are welcome! cudos are always welcome!
shall I mark this post as solved? or would you like to keep it open?
Message 9 of 11
We can close it. I can always open another one if I bump into any other issue. Have a nice day 🙂
Message 10 of 11
antonigornik
Hi, I was looking for some answers regarding soft body dynamics, found your test scene - really explains a lot, thanks! But I have one more question: what if I would like to have one of these balls bounce really high? Setting bounce higher than one gives some weird results...
thanks in advance!
Message 11 of 11
john.paul.giancarlo
Hello, I would suggest trying a different method in this case, maybe try increasing the mass and inicial velocity , try reducing friction also... I would have a look later as I am traveling today and get back to you when possible.
Have a great day.
