Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Snapshot don't save texture?
3 REPLIES 3
introbuck
512 Views, 3 Replies
Hi, i have an issue with snapshot. I don't know if it "feature" of Maya but when i snapshot that unwrapped box with texture on it the output jpeg file displays only black color, like on screenshot. It is so, how can i export image file so i can make some adjustments in photoshop?Screenshot_8.pngScreenshot_9.png
3 REPLIES 3
mspeer
in reply to: introbuck
Hi!
That's correct.
You need to open your image texture as usual in Photoshop and then you can import and overlay the exported UV map.
introbuck
in reply to: mspeer
So if i understand right it's impossible to export that shapshot jpeg image from maya so it can display the texture on it? Because in UV editor i clearly see texture.
mspeer
Hi!
Correct.
It's a UV snapshot, so it's only a snapshot of the UVs and nothing else.
If you want a screenshot from the UV Editor that also shows the texture, than you can
- use a simple screenshot feature from the OS or any other software,
- or use
textureWindow -e -capture "fileName" panelName;
 https://help.autodesk.com/view/MAYAUL/2020/ENU/?guid=GUID-D84149C3-63A1-4928-8F57-E90DE8F5DF4A
Technology Administrators
