Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Should I send workspace.mel to client?
3 REPLIES 3
yaschan
686 Views, 3 Replies
I want to make sure that the file paths of the textures stay relative. If I set the workspace I can see that the file path is gone and I look like I am working with relative paths.
If I send the .ma .mb file to client, should I also include workspace.mel? Does including or not including it affect the way how file paths are handled?
I would really appreciate answer for this.
3 REPLIES 3
mspeer
in reply to: yaschan
Hi!
If you send a complete project, then the workspace.mel is required to identify a folder as project folder and to handle the default project file paths. It should be included by default as it's inside the project folder.
To create and set projects when working with Maya is the key for using relative file paths (especially as paths are relative to the project folder and not relative to the Maya scene-file).
yaschan
in reply to: mspeer
Thanks for this, really appreciate it.
Yes I always set the project this way. Now, if I don't send the entire project, only .mb and a texture file, will the paths stay relative even then without the workspace.mel?
Jaakko
mspeer
Hi!
This would work if the paths would be relative to the scene, which they are not (at least not by default).
For this to work you would need to save (move) scenes to the root of the project folder, then it would work.
(I don't recommend this.)
