- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi!
I've edited the Maya.env file in ~/Library/Preferences/Autodesk/maya/2020 and added:
TMPDIR = '/Volumes/NVMe Array/Caches'
After restarting Maya and using the getenv 'TMPDIR' command, the variable has not been changed.
I also tried setting the variable in Maya using putenv 'TMPDIR' '/Volumes/NVMe Array/Caches'. Then, getenv DOES return the new path until I restart Maya, then the path has reverted to the default again.
Does anyone know why this is happening?
I'm using Maya 2020 on macOS 10.15.6
