Hi
It's my first hour of my first day of Maya and already bumping into way too many problems
What I am trying to do is change rendering engine from OpenGl to DirectX on Preferences window.
Problem 1 :
When I try opening preferences, this error pops up and does not open preferences window :
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/startup/colorManagementUtilities.mel line 99: Error has occurred while exporting color management policy file "C:/Users/이정훈/AppData/Local/Temp/tempPolicy.xml" .
Funny thing is when I try some actions, e.g F8 to change from object type to component type and open preferences again, it sometimes does open preferences window, but also sometimes crush into another error code :
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/startup/updatePrefWndUI.mel line 133: Value is out of range: 0
What could be causing this error to show up?
Problem 2
When I am lucky and finally open preferences, change OpenGl to Direct X,
When I press Save, this code appears :
// Error: A permanent scriptJob cannot be killed.
When I press Cancel, this code appears :
// Error: file: C:/Program Files/Autodesk/Maya2020/scripts/startup/prefsHoldCurrentState.mel line 1124: Cannot convert data of type int to type float[].
What is causing these?
Below are some things I tried :
- reinstalling did nothing
- changing prefs > prefold did not nothing
At this point I am thinking I should be relieved to close Maya without crushing into another error code
I really want to learn and like Maya
Please lmk if any other elaboration is needed
Thank you all in advance
