Set to Edge issue not working correctly
Message 1 of 1
i've been having issues while using the move tool, chiefly that it is not moving anything exactly perpendicular to the grid. Like if i select the back vertices of a cube, and attempt to lengthen the cube using the move tool, it will veer off slightly downwards, this is not affected by what viewport i'm currently in, it is always downwards. Anyone else encountered this problem, or have a solution to this problem?
Replies (0)
