I am looking for a way to better control which components (mainly faces) I select.
In C4D I have the options to select either all components that are partially within the selection marquee or all components completely within the marquee. Especially in ortographic views I find the second option much more efficient, but in Maya I only know the first option. Is there any way to adjust this?
I hope you can give me a hint here, thanks in advance!
Solved by mspeer. Go to Solution.
Hi!
You can only change the selection from partial face selection to center of face selection, in Preferences:
Selection -> Polygon Selection -> Select faces with (set to "Center")
Okay that option would be even more confusing and unsecure in my modeling process.
There are so many functions that seem self-evident to me not included in Maya.
Tanks anyway!
