Search and replace tool not working as expected
- Mute
- Permalink
- Report
I created a hierarchy of joints that were all uniquely named. I duplicated the hierarchy which all looked fine (root joint being given a 1 suffix)
I then used the Search and Replace names tool to find the word that prefixes all the joints and replace it with another but when I did so, the names were completely out of sync.
I checked the original hierarchy several times and asked a colleague to do so and no issues with names were found (I gathered them in a list and pretty printed them out to double check also)
The only way the tool seemed to work is if I had the joint hierarchy on its own in a separate file which then meant renaming the joints would work. I ended up with 4 separate files that I then had to import back into my rig file. I am testing again on a different machine today to test this out, but is this an issue anyone else has had?
Update: I have tested this on a few machines now, created new joint hierarchies with valid names. After duplicating the joint hierarchy and using the search and replace tool, it doesnt do like for like naming. The skin_jnt_ROOT joint was renamed to rig_jnt_toe_right. The cog name was given to one of the hand joints. The whole hierarchy is named incorrectly.
Seems all the names are there, but not in the right order.
I am now using a rename tool I wrote myself, but this is a fundamental tool that is having issues. Maya 2024 works fine.
Using Maya 2025.1 (Windows 10)
