Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
SCCM issues
2 REPLIES 2
274 Views, 2 Replies
SCCM issues
I have packed Maya and pushed it out with SCCM and it installs fine. My issue is when you go to run it and it wants the user to sign in to activate it. Is there a way around this? I have the education version.
2 REPLIES 2
If you are using the education version, then you should also look into setting up a license server. Otherwise each machine needs to be activated by hand either the Serial/Product Key. The SSO will retrieve this, but you should have been prompted during install for it.
Cheers,
Mike
dgorsman
In addition to the other comment, did you get the student EDU license, or the institutional one?  The latter is the only one with the network/multi-user license option.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
