- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created a simple python command and registered it as a hotkey.
The commands are as follows
- ResetTransform (Alt+w)
import maya.cmds as cmds
cmds.move(0, 0, 0)
- ResetRotate (Alt+e)
cmds.rotate(0, 0, 0)
- ResetScale (Alt+r)
cmds.scale(1, 1, 1)
This command is usually useful, but there is a problem. For example, if you want to reset the controller of your character's rig, you can use The selected controller's Transform, Rotate and Scale move to the origin.
I want to reset the values in the Channel Box/Layer Editor to 0, 0, 0.
I'll use Animation Mentor's Stewart to explain this. (Data>AnimationMentor_Stewart)
arm Rotate is not zero, so run this. its working.
But if you move your head and
cmds.move(0, 0, 0)
you'll notice that Channel Box / Layer Editor is not going to zero and is moving in a weird place.
It's happening in the rig I have, so I'm sure it's happening in all rigs as well.
What part of this command should I rewrite?
