removed textures while importing
ruwenzori
ruwenzori
I've just started learning maya and having some online courses from lynda. when i tried to import some scenes, i've noticed that some textures weren't visible-either hidden or simply removed due to an error.
i'm supposed to see the scene as it is on the above, but get the one in below instead.maya.jpg
also getting a warning that says "Warning: file: C:/Program Files/Autodesk/Maya2014/scripts/startup/rememberViewportSettings.mel line 43: Active stereo does not work with Aero enabled. Active stereo has been disabled." but as far as i understand from similar posts it doesn't have anything to do with the issue i'm having.
thanks in advance..
pshwayka
Click on the ground plane, and see what material is assigned to it in the attribute editor. If you click on the little checkerboard icon next to the Color field, you'll be able to see where Maya is trying to find the texture file. You can then click on the folder icon and re-direct it to the proper location for the texture file on your drive.
ruwenzori
i don't see how that's related to my issue in any way, the exact same problem occurs with every single scene i try to import. made clean installs of both windows and maya, using compatible version of mental ray with sp5 but the problem still persists.
here's the script editor report;
file -f -new;
optionVar -sv colorManagementColorPickerColorSpaceSelection "Rendering Space";
optionVar -iv colorManagementColorPickerColorMgtEnabled 1;
// Warning: file: C:/Program Files/Autodesk/Maya2016/scripts/startup/rememberViewportSettings.mel line 43: Active stereo does not work with Aero enabled. Active stereo has been disabled. //
// untitled //
doOpenFile ("C:/Users/e_top/Desktop/01_03.mb");
file -f -options "v=0;" -ignoreVersion -typ "mayaBinary" -o "C:/Users/e_top/Desktop/01_03.mb";addRecentFile("C:/Users/e_top/Desktop/01_03.mb", "mayaBinary");
closeAllNodeEditors;
closeHypershade;
requires -nodeType "mentalrayFramebuffer" -nodeType "mentalrayOutputPass" -nodeType "mentalrayUserBuffer" -nodeType "mentalrayOptions" -nodeType "mentalrayGlobals" -nodeType "mentalrayItemsList" -nodeType "mib_texture_vector" -dataType "byteArray" "Mayatomr" "2016.0 - 3.13.1.2 ";
# mental ray for Maya 2016
// Mental ray for Maya: using startup file C:/Program Files/Autodesk/mentalrayForMaya2016//maya.rayrc.
# mental ray for Maya: setup
# mental ray for Maya: initialize
# mental ray for Maya: register extensions
// mental ray Node Factory: loaded
evalDeferred "shaderBallRendererMenuUpdate";
# mental ray for Maya: successfully registered
# mental ray for Maya: loading startup file: C:/Program Files/Autodesk/mentalrayForMaya2016//maya.rayrc
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/AdskShaderSDKWrappers.mi
// generating Maya nodes...
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/architectural.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/architectural.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/base.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/base.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/basehair.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/basehair.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/bifrostMR.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/bifrostMR.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/bifrostphenMR.mi
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/builtin_bsdf.mi
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/builtin_object_light.mi
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/contour.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/contour.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/coreutil.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/coreutil.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/layering.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/layering.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/layering_phen.mi
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/object_light_phen.mi
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/paint.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/paint.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/physics.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/physics.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/production.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/production.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/subsurface.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/subsurface.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/surfaceSampler.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/surfaceSampler.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/userdata.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/userdata.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/useribl.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/useribl.dll
// parsing C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/include/xgenMR.mi
// loading C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/xgenMR.dll
get_mdl_modules('C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/mdl')
# ['maya_default'] #
requires "stereoCamera" "10.0";
updateRenderOverride;
// File read in 18.3 seconds.
commandPort -securityWarning -name commandportDefault;
// Error: line 1: (mental ray) : cannot load C:/Program Files/Autodesk/mentalrayForMaya2016/shaders/mayabase.dll, The specified module could not be found. //
// Error: line 1: (mental ray) : Unable to load file: mayabase.dll //
updateRendererUI;
// AbcExport v1.0 using Alembic 1.5.4 (built May 8 2014 13:47:10)
// AbcImport v1.0 using Alembic 1.5.4 (built May 8 2014 13:47:10)
// BifrostMain plug-in loaded (built Nov 30 2015 12:18:24)
updateRendererUI;
ruwenzori
