Referencing a single object from another file?
Toquitaa
Toquitaa
Hi there!
Let's say I have one big file with 500 trees, all in this single file. I'd call it "Trees_All" or something.
Now let's say I started a new exterior project and I want to reference only a single object/tree from the big file, how would I do that? From all I can see, referencing works by importing everything from the file?
I really just want to reference a few objects from the file but it brings everything, all trees, skybox, etc.
mspeer
Hi!
This is not possible.
You can hide objects you do not want to see after using "File Referencing", but you can't reference only a single object.
Based on your example it would be best to create a single file with the tree and then use this file as reference in the scene "Trees_All" and in your new project.
