Announcements
"xgen: Could not initialize the Patch renderer" error
Bryant4863
Message 1 of 22
Bryant4863
I tried creating an xgen description on a simple plane as an example and when I went to render with arnold, it said "xgen: Could not initialize the Patch renderer" I tried applying aistandardhair to it and it still threw the same error
Replies (21)
Message 2 of 22
sean.heasley
Hi @Bryant4863
Did you export the patches before rendering?
If that doesn't help, you may want to check and make sure your Arnold is up to date and also unload then reload all of the Xgen plugins.
Message 3 of 22
sean.heasley
Hi @Bryant4863
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 22
I also have this error  suddenly.  Arnold is refusing to render.  I never export anything for batch render.  I literately just start with a new scene, create a default sphere, create xgen description and render.
Message 5 of 22
syntaxcg
For me it's happened, but is strange... the xgen colour take the color of the sky... Help please
Message 6 of 22
Message 7 of 22
Wow, thank you so much
Message 8 of 22
ripi
Finally the solution I've been searching for! THANKS!
Message 9 of 22
so how can it works,have you solved?
Message 10 of 22
Have you searched?so upset
Message 11 of 22
Yes,It has been solved. If you re open the Maya file, it will be normal and no error will be reported.
Message 12 of 22
Message 13 of 22
Could you let me know what exactly to do? I didn't get that; what do we have to fill in the Xg base file and Xg delta files column? What names, names? Thanks in advance!
Message 14 of 22
Also, shall we turn on XgExport As Delta?
Message 15 of 22
Thanks to solving the issue
Message 16 of 22
patrick.schock
Autodesk Support
Autodesk Support
Hello @Anonymous,
Enter „name“ in the field XG File Name, “name” at XG Base File and “names” at XgDelta Files. You can leave Xg Export As Delta unchecked.
For more information about the settings, please see this post in the Arnold Forum: How Do I Actually Assign Standard Surface Shader To XGen Collection?
Hope this helps!
Best regards,
Patrick
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png”
Message 17 of 22
I have the same problem but ''name, name, names'' doesn't work at all. I have applied aiStandardHair material, Skydome light, set the renderer to Arnold Renderer in Xgen, saving my scene all the time and still getting ''# Error: line 1: [xgen] Could not initialize the Patch renderer.'' I absolutely don't know what to do anymore. Sometimes when I create more descriptions within the same collection, it renders just a few of them randomly (even though using the exact same settings) and I'm still getting the same error.
Message 18 of 22
SOLVED!:
For anyone having the same problem as I had, make sure you DON'T change the name of the object Xgen is applied to after it was applied! Do it BEFORE applying. Otherwise, it will lose the connection between the object and Xgen. That's what I did and didn't realize that such basic stuff can make such a mess. 😂
Message 19 of 22
americalFQ3CT
Observer
Observer
THIS is what finally worked for me. I had XGen grass assigned to "pPlane1" and changed the name in the Outliner to simply "grassPlane". When I read this post I changed it back to "pPlane1" and I knew it was going to work when all the fans in my tower started to rapidly speed up. Thank you so much for this! Instantly GOAT'd.
Message 20 of 22
wangziheng0426
Community Visitor
Community Visitor
may be u need this code: optionVar  -iv "exportIncludeHistory" 1 -iv "exportIncludeInputs" 1
