Maya Forum
Welcome to Autodesk’s Maya Forums. Share your knowledge, ask questions, and explore popular Maya topics.
Python Arnold SSS Set Name Command
8 REPLIES 8
Message 1 of 9
3985 Views, 8 Replies
Hey guys,
I want to write a Python script to add objects to a certain SSS Set Name but the Python command doesn't show up in the editor and I can't find any documentation for the command. Does anyone know how to do it?
Cheers,
David.
Tags (2)
8 REPLIES 8
Message 2 of 9
faline.custodio.da.silva
@Anonymous
cmds.select( 'spinning_ball', r=True )
cmds.rename( 'sphere1' )
replace 'spinning_ball' with the name of your node and 'sphere1' with what you want to name it.
Faline Custodio Da Silva
Message 3 of 9
No am not trying to rename something. I am trying to set an attribute. Specifically a certain Arnold attribute. Unfortunately the Script Editor only echos attributes with a MEL command. However it does seem to echo some Arnold commands too. This is called a Set Name but when assigning a set name to an object it doesn't actually create a set new set in the outliner so I am at a loss as to how to script this.
Cheers,
David.
Message 4 of 9
Stephen.Blair
SSS Set Name is a string. It doesn't create a set in Maya.
See https://support.solidangle.com/display/AFCUG/Sub-Surface+Scattering#Sub-SurfaceScattering-SSSBetween...
The attribute names is aiSssSetname
// Stephen Blair
// Arnold Renderer Support
Message 5 of 9
in reply to: Stephen.Blair
Hi everybody,
I'm having the same problem ... I'm trying to set the "SSS Set Name" attribute ... and with this script I'm able to get its value:
import maya cmds as cmds
sel = cmds.ls (sl=True)
cmds.getAttr (sel[0] + ".aiSssSetname")
but I'm not able to SET its value with this script:
cmds.setAttr (sel[0] + ".aiSssSetname", "share_SSS")
It gives me this error:
setAttr: 'pSphereShape1.aiSssSetname' is not a simple numeric attribute. Its values must be set with a -type flag.
Do somebody knows which is that flag ???
Tags (1)
Message 6 of 9
Stephen.Blair
@Anonymous wrote:
Hi everybody,
Check the setAttr documentation.
// Stephen Blair
Message 7 of 9
Ok finally I got it !!! ... Thank you Stephen
to SET that attribute:
import maya.cmds as cmds
for each in sel:
        cmds.setAttr (each + "aiSssSetname", "share_SSS", type="string")
where "share_SSS" is the new value
Message 8 of 9
Sorry , I forgot one dot ...:
for each in sel:
        cmds.setAttr (each + ".aiSssSetname", "share_SSS", type="string")
Message 9 of 9
Lindsey_Robbins
TYVM, this was driving me nuts, since the SSS set name doesn't show up in the attribute spread sheet.
