Problems with texture resolution
estuary24
Message 1 of 9
estuary24
Hello. I have a textured mesh. The texture appears very low resolution. On the head the texture looks broken, although the texture shell map looks good to me. I really need help to make the resolution of the texture higher. It is so blurry and pixelated. Please, I need help figuring this out. I have no idea how to fix this. I attached my file screenshots. I couldn't figure out how to attach the mel file.
Does anyone have an idea what I did wrong why my texture is so small resolution?
Replies (8)
Message 2 of 9
damaggio
you didn’t say the most important thing , the texture resolution.
Message 3 of 9
estuary24
Thank you so much for your reply. I don't know how to increase the size of the square in the UV editor. I assumed that would make my texture bigger. Right now the resolution is small, but the PSD file I am using has very high resolution. I think either my mesh is too small or the texture square in the UV editor is too small. I wish I knew how to increase the resolution in the texture square in the UV editor. Do you know what might be wrong is it my mesh or the resolution in the UV editor box?
Message 4 of 9
damaggio
I’m boarding a flight , someone else will help you shortly.
Message 5 of 9
damaggio
Please also answer to mr mspeer on your previous post from June 2021 which is related to this current one.
https://forums.autodesk.com/t5/maya-forum/image-in-uv-editor-is-super-small-and-low-resolution/m-p/1...
Message 6 of 9
mspeer
Hi!
Please provide the scene-file and the texture file for further help.
Message 7 of 9
estuary24
Where can I attach the mel and psd files?
Message 8 of 9
estuary24
**** is not letting me attach a mel file in this forum. It says maya files not allowed. How can I share my file and textures?
Message 9 of 9
damaggio
You need to Zip the file first, scene and textures.
