& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I have a rather stupid question. I switched from Maya 2020 to Maya 2024 and now I have a problem with the selection tool. Everytime I drag and select I only select the faces on the front. But backface culling is turned off in the settings. Are there any settings that I am missing?
Thanks in advance
You have turned on camera based selection.
Is there another one? It is turned off in the settings 😕
Here is a similar post where the culprit turned out to be the backface culling option on meshes.
https://forums.autodesk.com/t5/maya-forum/marquee-selection-bug-camera-based-selection-turned-on/m-p...
You can also check to make sure you are using the right graphics card driver for your version of Maya.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
