Problem with Renderman Plugin
 I have a problem with Student Maya 2018, I can't load the plugin "Renderman"
I had this message when I try to load it :
// Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/pluginWin.mel line 290: UnicodeDecodeError: file C:\Program Files\Pixar\RenderManForMaya-22.3\scripts\rfm2\config.py line 503: ascii // // Warning: file: C:/Program Files/Autodesk/Maya2018/scripts/others/pluginWin.mel line 290: Failed to run file: C:/Program Files/Pixar/RenderManForMaya-22.3/plug-ins/RenderMan_for_Maya.py // // Error: file: C:/Program Files/Autodesk/Maya2018/scripts/others/pluginWin.mel line 290: (RenderMan_for_Maya) //
I reinstalled Maya and Renderman many times.
It's not the first problem with a plugin, it was the same with "CurveRecreator". The problem came from my username because it was an accent. Therefor I created a new administrator, and delete the old. Normally, the problem would have disapeared, but no. My computer keep a save my old username, then it create a bug ? Or is it an other thing ?
Kind regards.
have you tried contacting renderman support?
This is not an autodesk product
dscreddy2000
Community Visitor
Community Visitor
Same problem with my pc and even i have student version
