Problem with Multi-Cut
I just need to make a parallel cut but it just does not work the way it should. Multi-cut makes it be done intermittently...
(I've tried Clean Mesh, Del history and reset Tool).
Christoph_Schaedl
Could you upload the mesh here?
https://linktr.ee/cg_oglu
Yes, thank you.
mspeer
Hi!
You have vertices on top of each other.
... and there are more.
Try Edit Mesh -> Merge.
Thank you so much!)😅
