Problem with move rotate and scale tools
amt3cass
Message 1 of 9
amt3cass
I'm having a problem with the Move, Rotate, and Scale tools in my Maya.
Replies (8)
Message 2 of 9
mspeer
Message 3 of 9
amt3cass
When I clicked on the URL I was denied access.
Message 4 of 9
mspeer
Hi!
Maybe deleted by admin (it was a duplicate of your question).
Your video however is not available, please add more details to your question.
Message 5 of 9
amt3cass
When ever I try to move, rotate, or scale either a face, an edge, or any verticies the move, rotate, and scale tools will not work the way i need them to. Here is a video showing my issue:
Message 6 of 9
amt3cass
Message 7 of 9
mspeer
Hi!
That's Slide mode (CTRL + SHIFT + Move).
Check your input device, reset the tool settings and if this all does not help,
try a reset of your preferences.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
Message 8 of 9
sean.heasley
Hi @amt3cass
It looks like you may have a few settings toggled/changed in the tools.
I'd recommend double clicking on each tool and then select Reset Tool.
If that doesn't work, you can try deleting your settings/preferences.
Please let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
