Problem renaming object
arcon76
arcon76
I have a problem when trying to rename an object. It won't allow me to set the name instead keeps increasing the suffix by 1 every time. There is no duplicate object (I have checked with select code), and I have tried optimize scene size and re-import.
I cannot share the scene due to copyright, but may be able to send it to a private Autodesk server if a link is provided, thanks.
_sebastian_f
make sure there is nothing in the scene with the same name you want to give the object. names of display layers, shaders or file textures also count to name a few.
arcon76
As mentioned same name was already checked. However just now the problem rectified itself by grouping the object under an empty group, then it could be renamed and retain the name after ungrouping. Its unclear if this was a memory glitch or something to do with a previous import causing a problem - I have heard using namespaces can cause future renamaing issues.
yamajigui
I don't know if it will actualy helps, but i faced a similar problem. I imported a named mesh as "chef_hat" and every time i renamed other meshes/groups it was includdig a prefix " chef_hat: ". So I restarted Maya and the problem disapeared.
raunak4AC3L
Community Visitor
Community Visitor
i tried... but not working... my issue is with the 2nd bone.... only in the second bone automatic hierarchy renaming not working... up and down working perfectly...
