Hello Guys,
I have been facing an issue with maya curveinfo node,
so i have an eg(excuse the names),
cube_cone_curves
i created cube curve by snapping ep curve on cube poly
and then created another curve snapping points on cone poly
and parented both the curveShapes, with below command
parent -r -s <curveShapeName> <transformName>;
and then duplicated curves and and renamed again the curves and shapes to avoid name clashes
Now the problem begins
firstcase:-
1 transform 2 shapes,
i want "knot values" of both the shapes, so i create a curveinfo node and gave inputCurve for cubeShape 1
query knot values with
cmds.getAttr("curveInfo3.knots")
disconnect and connect again inputCurve for Coneshape 2
secondcase:-
i want "knot values" of both the shapes, so i create 2 curveinfo nodes and connect cubeShape 1 and coneShape 2 to curveInfo 1 and curveInfo 2
cmds.getAttr("curveInfo1.knots")
cmds.getAttr("curveInfo2.knots")
if you see the results its different
12 knots for cone
18 knots for cube
There are workarounds but needed to bring to your notice,
it makes it difficult to use single curveinfo for multiple curves(during for loop, connect and disconnect to multiple curves), it might give wrong values
or i also might be wrong its purpose is to be used once
and for second curve we need new curveInfo, waiting for your feedback
tried attaching .ma file for ref but not able to, let me know the steps for uploading if needed
