Help! I am using the student version of 2016.5 and I can't locate Terminal.term or mayaENV.sh in applications/maya2016.5/ or in applications/maya2016.5/maya/contents/bin. It is just not there. I have a very large format rendering that I need broken up in a few tiles. I tried using the Mac Terminal with the proper commands, but it keeps telling me "Render: not found".
This is what my Terminal looks like:
iMac:scenes GraphicDesign4$ Render -r mr -v 5 -x 2910 -y 1110 -reg 0 582 0 1110 -rd images -im test01 Test_Barricade-3D01.mb
-bash: Render: command not found
Can anyone help me with this or point me to the Maya Terminal?
TIA
As this was covered on Reddit, I'll translate the info here for others:
Like ehuss said, you can use the full command
/Applications/Autodesk/maya2016.5/Maya.app/Contents/bin/Render
or as we both pointed out, add this to your PATH variable. If you aren't sure how to do this, from the terminal run:
cd ~ nano .bash_profile # Add this line to the end of this file export MAYA_UTILITY=/Applications/Autodesk/maya2016.5/Maya.app/Contents export PATH=$PATH:$MAYA_UTILITY/bin # CTRL-O then Y to write this and CTRL-X to close nano # This part I'm not sure of. As this is the .bash_profile file, you may need to logout/login to take effect. Maybe even reboot. Otherwise, try this: source ~/.bash_profile # Close the relaunch Terminal and try running the Render command.
I'm still getting the same error after following your directions.
It is either my install is bollocksed up, or pilot error. I'm in a bit of a time crunch, so I installed 2015 and everything worked flawlessly. When I finish this project I will try to reinstall 2016.5.
here is the list of /bin
ls -al /Applications/Autodesk/maya201x/Maya.app/Contents/bin/
I was able to revive an old MacBook hanging around the house (was missing the charger previously). I've recorded a quick capture for you to use as reference. I was using 2016.5 (initial, not SP2 which shouldn't make a difference). As long as you're using the default shell that OSX gives you (not switching it to /bin/bash or other) this should work just fine. Sorry for no voice, the mic would kill your ears from the keys. Also sorry for any blurry text, the screen is 1440x900, not ideal in the slightest. Pre-retina machine.
