No object matches name when mirror
nelo.2003
nelo.2003
When i mirror an object It does the function but It appears an error message saying no object matches name. I tried deleting history, reseting maya preferences and the huge problem is that It happens at any Maya files, even If I start a new maya document and I try to mirror an sphere It says the same error message. Please help!! 😞
mspeer
Hi!
Mirror does not work with NURBS, please make sure to select a polygon object before you use Mirror.
For further help, please provide a Maya scene-file and the complete Script Editor Output, after you used Mirror.
nelo.2003
Hey, I finally solved It! It was the history button at the top of the interface, It was disabled and It was causing that, anyway thanks! 😄
timodeet
Community Visitor
Community Visitor
Thank you so much, to those who don't know its between symmetry and rendering stuff. Kept randomly getting this and had already reset prefs once
