'No object matches name : vaccine_gene' Error
zzziizzi
zzziizzi
I'm trying to save the maya file, but the error pops up and it would say
'Error : ValueError : (file address) line 74 : No object matches name vaccine_gene.
What is vaccine gene and why would it keeps me from saving the scene?
I didn't erase any of the file in the autodesk maya file
and this is the new file I've started working on from about 1 hour ago
I can't understand why would this error occur.
Can anyone explain about this?
nelsoncruz
Your scenes and setup seem to have some malicious code that has been floating around for the past few years.  The recommendation is to install Security Tools for Autodesk® Maya® | Maya | Autodesk App Store.  You will need to run this on all your scenes to remove the malicious scriptNode.
Nelson
Nelson Cruz
Manager, Software QA Engineering
Installation & Licensing forums | Contact product support | Autodesk AREA
zzziizzi
@nelsoncruz
Hi. Thanks for the reply.
I'm trying to install the Maya Security Tools by the link you gave, but it pops up the error when trying to open the pkg file.
“MayaScanner-macos.pkg” can’t be opened because Apple cannot check it for malicious software.  The software needs to be updated."
What is the problem? How can I install it?
nelsoncruz
I replied to that other thread with a potential workaround to bypass mac gatekeeper.
Apple can’t check app for malicious software - Apple Support (CA)
Nelson Cruz
