need help with boolean problem !
mikhailkonstantin3d
mikhailkonstantin3d
hello friends .. I have this problem in Maya when am trying to Boolean (difference) it is not working as it should it's just drawing itself on the other object that should be cut !
 those is the two partsthose is the two partsthe big one must be cuttenthe big one must be cuttenchose boolean "difference" so the small piece disappeard but didn't cut the big piece it draw itself !chose boolean "difference" so the small piece disappeard but didn't cut the big piece it draw itself !any help ?
mikhailkonstantin3d
oh thanks .. I found the solution .. I had doubled edges there .. that was the problem .. I deleted one of them and all done
sean.heasley
Hi @mikhailkonstantin3d
Glad you figured it out! Thanks for explaining what you did to solve the issue I went ahead and marked it as a solution!
mikhailkonstantin3d
oh thanks 🙂
