Need help for Shattering object.. using Maya 2018
jchen210149
Message 1 of 10
jchen210149
I'm trying to use the Shatter effect on a house model and it give me an error almost all the time
I have tried (delete the history, freeze transformation, assign new material, decrease the shards ) but it just keeps giving me errors,sometimes even crash.
It did apply successfully one or two time,  very confuse now.....
thanks for all helps
Replies (9)
Message 2 of 10
mspeer
Hi!
The solid shatter script only works with "clean" meshes. Here this means a simple and clean topology creating one closed object.
Based on the provided screenshot your object does not look like this.
Sorry, I doubt you will be able to use solid shatter with this object.
You can try one of the other shatter options.
For further help, please upload the scene-file.
Message 3 of 10
jchen210149
Thanks for helping
I try only do one object (01.jpg) clear history and apply new material
it works and than show another error (00.jpg)
scene file https://drive.google.com/file/d/1p_hStQyB8Ik7MwRJm1SI_qT9LwHZ6Mbx/view?usp=sharing
Message 4 of 10
mspeer
Hi!
There is a problem with the material connection of polySurface1.
The easiest way to correct this is:
Simply assign a new material to polySurface1.
Message 5 of 10
jchen210149
I did apply a new material
and it works
but than it crashed and show 01.jpg...
Message 6 of 10
hoganburrows
Maya will not help you.
try pulldownit, it’s very affordable and the demo will let you do a small number of fragments.
If you have the time, do it by hand 🤮
please sort you destruction pipeline Autodesk!!
Message 7 of 10
jchen210149
sorry I don't know what you mean...
I should use Pulldownit istead of Maya shatter?
..and I mean 00.jpg at message5,I typed it wrong
Message 8 of 10
mspeer
Hi!
Please be more specific, what does this mean:
"but than it crashed and show 01.jpg..."
What do you do before it crashes.
For me it's:
1. Open the scene
2. Select house (polySurface1)
3. Assign new Material (Maya > Phong)
4. Apply Solid Shatter with default settings
=> Done, no crash.
Message 9 of 10
jchen210149
1. Open the scene
3.Delete history
4. Assign new Material (Maya > Phong)
5. Apply Solid Shatter with default settings
=> Done, crash.
Message 10 of 10
mspeer
Hi!
So it crashes right after finishing the shatter operation without any further action by you?
That's strange.
Based on your scene it looks like you use the first Maya 2018 release, so i recommend to update to Maya 2018.5 (the version i used to test this).
You may also try a reset of your preferences after you installed Maya 2018.5.
Rename the folder prefs in folder 2018 to something like prefs_backup, or to reset everything, the folder 2018 to 2018_backup (or even the maya folder to maya_backup). Maya creates new folders (don't copy preferences from previous Maya versions). Detailed at:
https://knowledge.autodesk.com/support/maya/troubleshooting/caas/sfdcarticles/sfdcarticles/Reset-May...
