Need Help fixing uneven edges
Hi everyone,
How do I make my edge look like the one in the other picture I provided, mine is not straight and identical to the others, I was following a tutorial and I'm 30+ mins in and just realised that the edge is wrong so how I can fix, I believe it has something to do with vertex but I'm unsure how to do it exactly I've tried using the multi cut tool to no avail.
help me please its for my assignment.
Try scaling the verts of your edge in one axis.
JabbaTheNut
One approach would be:
1. Delete the triangle
2. Extrude the edge to create a proper quad replacement.
3. Weld the vertices at the end as necessary.
Another approach would be:
1. Use the multi-cut tool to bisect the triangle (i.e., use the 90 degree corner to start your edge and finish the edge in the middle of the hypotenuse.
2. Move the vertex at the middle of the hypotenuse to your desired location (to create the rectangular shape).
3. Delete the edge you created without deleting the vertices.
