Need Help, coming from 2014 to 2017
Hey everyone! I'll cut right to the chase. Im coming from an older version of Maya to 2017. Im also a novice in general with Maya. I'm trying to select a vertex after converting a polygon to subdiv. However every time i try to select a vertices it returns to object mode. How can i select a vertices after subdiv?
mspeer
Hi!
Change Mode/View from "Standard" to "Polygon".
But i recommend not to use Maya Subdivision surface anymore (no further development since years), use smooth Mesh (Preview) instead.
tony.su
Autodesk Support
Autodesk Support
As mspeer said Change Mode/View from "Standard" to "Polygon", or change viewport renderer from VP 2.0 to Legacy Default Viewport.
But subdiv is not a good choice.
Tony Su
Product Support
