Must all parameters be manually typed in Attribute Spreadsheet?
litote
Message 1 of 9
litote
When changing parameters for an attribute in the Attribute Spreadsheet (Windows-General Editors-Attribute Spread Sheet), can they only be manually typed in, or is there a menu for parameter options you can pull up within the Spread Sheet?
e.g. for Arnold-Subdivision-Type, there is catclark, linear etc. I have to look in the Attribute Editor to note them and then manually type the one I want to set it to.
Replies (8)
Message 2 of 9
sean.heasley
Hi @litote
All of the settings found in Spreadsheet Editor can be found in their native locations in Maya, the sheet is just designed to have them all in one location.
For subdivisions like in your example. if you open the Attribute Editor and navigate to  Smooth Mesh-> Subdivision Levels you should see the options for catclark, linear etc.
Let me know if this helps or if you need any more assistance!
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Kudos are greatly appreciated. Everyone likes a thumbs up!
Message 3 of 9
sean.heasley
Hi @litote
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Message 4 of 9
litote
Hello Sean,
Am I correct in assuming you can't pull up a menu in the spreadsheet to list the options for parameters you can find in Attribute Editor? In other words, you must find the name of the attribute first in AE then manually type it into the spreadsheet? I was hoping it could all be found in the spreadsheet so you didn't have to hunt about.
Message 5 of 9
sean.heasley
Hi @litote
What you can do is go to the 'All' tab and you'll see a list of every parameter in the spreadsheet you can change.
That said, if you know what parameter you wish to change you should be able to type it into the search bar and see it appear.
Message 6 of 9
Hi Sean,
What he means isn't to find the attribute to change, but to find a list of the values an attribute can be.
@litote Unfortunately I don't think you can do this by default in Maya, but I think it would be a great feature request and I would vote for it too!
Message 7 of 9
litote
I found a plugin that Arvid Schneider has kindly provided on his site for free that does just this:
http://lightshader.de/documentation/attributecontrol/
Message 8 of 9
sean.heasley
Ah ok thank you for clarifying @Anonymous wasn't sure if I was understanding correctly Smiley Tongue
@litote great I'm glad that plug-in works for you!
Is there anything else you need assistance with?
Message 9 of 9
sean.heasley
Hi @litote
Just wanted to check in to see how things were going. Are you still having this issue?
If your issue is resolved, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
