Move and Sew UV hotkey
Hi guys, I would assume there is a simple way to do this but I'm probably overlooking it. I have set various hotkeys in the past for doing stuff like beveling and bridging but for some reason I cannot find the command to set a hot key to for moving and sewing UV edges. It's really annoying to constantly pull up a menu and to manually click the button. I would have thought the option for it would be under the UV Editor section but it is not. Nothing comes up when I try searching Move and Sew or polyMapSewMove which is what pops up in the command line when I execute the command. Can someone point me to where I can find the command and hotkey it?
Thank you in advance.
sean.heasley
Hi @Anonymous and welcome to the community!
What version of Maya are you using?
This works fine in 2018 but may have issues in earlier versions of Maya.
Let me know if anything changes!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
That explains it. I currently am working with Maya 2017 so I will update to 2018 and let you know how it goes. Sorry for the late response.
Wow, so many more hotkey options in Maya 2018. Thank you very much for the help sean.
sean.heasley
Happy to help Smiley Happy!
