Announcements
minimum requirement
minimum requirement
minimum requirement
hey i have intel pentium g4560 processor Instruction Set ExtensionsIntel® SSE4.1, Intel® SSE4.2 . its has 2 cores and 4 threads its is a 64 bit processor and i have a gtx 1050 ti gpu and a 8 gb 3000 mhz ram will i be able to reum maya autodesk?
sean.heasley
Hi @Anonymous  and welcome to the community!
Yes you should be able to run Maya.
For future reference you can always check our system requirements and certified hardware list if you have doubts about your hardware.
You can find our certified hardware list here!
You can find our certified system requirements here!
sean.heasley
Hi @Anonymous
I'm just checking in again to see if you need more help with this. Did the suggestion I provided yesterday work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
